Signal Generators
signal
Hi
I have signals generated in matlab "wave file" and i am reading these signals in Labview through "read file" there is a diffrence in the frequencies of the signal generated in Matlab and Signal detected(read) in Labview eg.
signal frequency generated in matlab                  signal frequency detected in labview
                1100Hz        1096.79Hz
                1200Hz        1195.99Hz
                1500Hz        1510.09Hz
                1700Hz        1750.31Hz
                2000Hz        2000Hz
                2200Hz        2173.23Hz
                2500Hz        2387.23Hz
               2700Hz        1345.99Hz
why are these frequencies different at many points and why are they same at some(2000Hz) point. i have used Tone measurement and Transition measurement VI's to determine the frequencies of signal.
Regards
Madd
Message 1 of 17
(9,294 Views)
madd,
Are the signals generated in Matlab exactly 1100 Hz, 1200 Hz, etc?  Or is that a different displayed number that might have the significant digits set to 2?  If you can explain how a little more about how the signals are generated in Matlab it may help.  Thanks
Brian T
Message 2 of 17
(9,285 Views)
Tnx
For ur response. I have signals which i have modulated in Matlab using "MPSK" simulink block providing it with the frequencies as mention above.The modulated waveform ,when i claculate the frequrncy by claculating time period of waveform and taking its inverse(f=1/T) just by watching the plot of modulated waveform it comes exaxtly same as i have mentioned in "MPSK" block.But when i read these frequencies in Labview they have a pattren as i have mentioned befor.Is there any thing wrong with my version i am using . I am using 8.5 evaluation version. which i dont think will be. Looking for ur further guidence.
Regards
Madd
Message 3 of 17
(9,273 Views)
How exactly are you calculating the period of one waveform?  And what sampling rate are you using in order to derive this?  You may need to increase the sampling rate when you are reading the signal in LabVIEW.
Message 4 of 17
(9,249 Views)
HI
LOOKING AT  THE SCOPE SIGNAL I HAVE GENERATED I CAN FIND THE TIME PERIOD OF THE SIGNAL AND CAN CALCULATE THE FREQUENCY . ALSO HERE I HAVE ATTACHED THE SIGNALS I AM GENERATING UISNG "mpsk" I AM GENERATING ALL THE FREQUENCIES USING THIS CARRIER FREQUENCY.
REGARDS
MADD
Message 5 of 17
(9,228 Views)
Could you post your code, both from Matlab and LabVIEW, so I can get a better idea of whats going on?  Thanks
Brian T
Message 6 of 17
(9,213 Views)
Hi
i am really very sorry everyday i was watching ur response but i now i saw that i have no posted the attachements i have mentioned in my previous reply.here are the matlb attachments and the labview attachments i have made .i am setting the carrier frequecncy by using matlab "Carrier Frrequency"(2000) block option.the scope plot i am using is to physically calculate the time period of wave and taking inverse to find frequency. In labview two Numeric indicator tells different story regarding frequecy of the generated signal(in Matlab).one shows a shlight diffrence and other has more.
Regards
Madd(Now COMSIS)
Message 7 of 17
(9,195 Views)
Message 8 of 17
(9,194 Views)
HI
can u also explain me about timing recovery in PSK/QPSK(i have gone through white paper on NI platform) .Or can u guide me about some forum where i can find it by implimentation perspective not by long theories and equations. how would i implimnet it in Labview. any good clue or book or paper which can be helpful in labview implimentation of timing recovery. I know this is not a proper platform to ask this question but Generalllly if u could helpSmiley Indifferent
Message 9 of 17
(9,181 Views)
COMSIS,
The reason why you are observing different measurements using the Tone Measurement VI and the Timing and Transition Measurements VI is because the way each of those VI's actually work. With the Tone measurement VI, which measures the period of a signal and takes the inverse, it is possible that the funtion misses the actual period by a few samples, or includes a few additional samples in the same period. This creates what is called spectral leakage, which when taking the FFT for a final frequency determinatio, makes it seem as if the FTT is shifted slightly and that is why you seem to be reading a slighly different frequency. Conversly, the Timing and Transition VI, actually counts the rising edges and measures the dt. This is a more accurate measurement because the is no room for spectral leakage to take place.
For more information about spectral leakage please refer to the following links;
http://zone.ni.com/devzone/cda/tut/p/id/4892
http://digital.ni.com/public.nsf/allkb/2A8C234B3F3F4B81862567E60073D997
http://digital.ni.com/public.nsf/allkb/4985224270D324A086256936005879BB
Eli S.
Message 10 of 17
(9,167 Views)
