Signal Generators
sine wave generation
can somebody tell me please what is the difference in sine pattern VI,Sine wave VI and sine VI.
i know that generate continuous sine wave 2 channels use sin pattern VI. Basic function generator use sine wave VI. Compute sin wave VI uses sineVI.
is functionality of all these 3 VIs almost the same?
moreover sine pattern VI and aine wave VI uses samples as input argument. does sample means periods of a sine wave?"
(6,832 Views)
Hello hood1,
sine.vi calculates the sine of an input.
sine pattern.vi generates a sine wave with the parameters specified as input (amplitude, phase, number of cycles). It outputs a DBL-array, its length can be set by the number of samples input.
sine waveform.vi also generates a sine wave but the output will be of waveform data type.
Hope this helps you understand the different VIs.
I Schumacher
Application Engineering
PS. In future, please post as question only once in one thread. Thanks.
(6,832 Views)
