SignalExpress
Acquiring continuously not possible? NI-5133
Hello everybody,
i would like to record continously (phase continuous!) with SignalExpress and NI-5133.
When i create a "NI-SCOPE ACQUIRE" there are TWO options for acquiring: "N Samples" and "Continuously", but "Continuously" is greyed out, so I cannot select is.
When i uncheck "Use relative initial time" und "Advanced" it won't work either.
Is there any solution for my problem?
Thank you and best regards!
DahBenni
(5,014 Views)
Hi DahBenni,
Due to limitations of the USB bus, you will not be able to continuously acquire at the full rate of the device.
The following KB explains this issue.
Does the NI USB-5132/5133 Support Continuous Acquisition? - National Instruments
http://digital.ni.com/public.nsf/allkb/63AFE9F8DB0F7F5586257811006E7E51?OpenDocument
Best regards!
(4,947 Views)
