SignalExpress
Can't get SignalExpress to display data as a thermometer
I am unable to get my data (from an RTD) to display as anything other than ax XY plot - no other options appear in the right-click menu on the plot area.
Any help with this would be appreciated.
Corey
(6,180 Views)
Had the same problem.
Try this - worked for me.
Take outputs fromt eh "Acquire Signals" and then ADD STEP - Processing - Amplitude
Now plot the Amplitude of the rtd - this will allow you to display as a Thermometer.
(6,162 Views)
Hey Corey,
You should be able to view your reading as a thermometer. You need to be sure that your sampling mode is "1 Sample (On Demand)." You can set this up in the DAQ Assistant step. Once in this mode, if you right click on your Data Display, you should navigate to View As»Thermometer. This will allow you to view your data reading as a thermometer.
(6,157 Views)
