SignalExpress
Can't obtain running Leq from recorded data
I have recorded some data using SignalExpress and Nose and Vibration Toolkit, 2010. I'm using a Larsen Davis mic with an NI9234 and NI9162.
Basically, i have set up a few displays to monitor the data being recorded in realtime. One of these is running Leq. The values during recording look reasonable. I specify that i want to save the sound pressure, and the running Leq, then record some test data.
I then move to playback, and create a Sound Level step and add a running Leq display to Data View. The displayed data does not match what was displayed during recording. If i add a running Leq display to Data View direct from the data set, it works fine. (see the image below).
What am i doing wrong? i assume that it is possible to produce running Leq once data has been recorded...?
(5,726 Views)
Also, I should have mentioned that it doesn't mater if i use the filtered sound pressure, or the unfiltered sound pressure as the input for the Sound Level step, both have results which are negative (and don't match what was recorded).
(5,720 Views)
Hey Nick,
As I said in the email I sent you with regards to SR number 1775179, this is a known issue with SignalExpress. Basically what is happening is you are getting a different dB reference level for your playback vs your real time recording. The playback defaults to a reference of 1.00, so if your signal average is 0.005, then in dB it should show around -45dB (which it does).
Workarounds
#1. Export newly collected data for post-processing while in the Monitor/Record mode (can't be done if reprocessing old collected data that can only be viewed in the Playback mode).
#2. Export old collected data for reprocessing while in Playback mode, then correct the dB reference on the exported data.
The dB reference can be corrected by running a LabVIEW VI within the project. Use a 'Run LabVIEW 2010 VI' Step to call Sound and Vibration VI 'SVL Set dB Reference (N Ch - 1 Ref).vi' You will have to save the VI as reentrant before using it in the 'Run LabVIEW 2010 VI' Step.
-Nathan H
Software Developer
(5,709 Views)
