SignalExpress
Can't open project logs missing
I am not able to open my SignalExpress project after a system crash.  The error message is showing a list of "Missing log files".   I don't need any old data - is there a way to open the project?
Thank you for your kind help.
(5,652 Views)
what is happening after you clear the error message(s)?
It should launch into whatever state it was in since the last save.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,630 Views)
Hi Nkoka,
When you tried to open a project does SignalExpress shows you an error or just the message of Missing log files?
Have you tried to repair the software? Control Panel>>Uninstall a program>> National Instruments Software>> double click >> NI SignalExpress>>Repair
Let me know how it goes,
Regards
(5,584 Views)
You are correct.  Finally I got it opening today.  But that error message keeps coming back every time I open the project file.  Is there a way to get rid of that error message?
Thank you
(5,547 Views)
Hi there,
When you open the project, are all the files that you need? Did you repair your SignalExpress?
Regards
(5,526 Views)
