SignalExpress
Can't view my spectrum (protocol/tdms)
I've recorded a lot of acceleration signals (with their spectrum) in SE 3.0.
When I'm trying to load the data from the protocols, I'm only able to load the raw data although the spectrums are displayed in the protocol tree too.
When I'm using the export functionality (Ascii/excel) only the header is exported...
When I'using the import tdms file option, a log is imported but contains no data or name.
The tdms file is about 1,6 MB and could be opened in labview 8.6 without any problem... the spectrum data could be read.
How could this bug be fixed?
Karsten
(6,820 Views)
when I'm opening my spectrum-tdms file with labview, I'm only able to read one of my four channels - and I don't know which...
when I'm opening my acceleration-tdms file I see all channels...
(6,817 Views)
Hi pho_nox,
can you please attach your SE project?
So maybe I can reproduce this here.
Regards
DianaS
(6,789 Views)
I attached the project.
(6,779 Views)
 Hi Pho_nox,
everything seems to work fine here with your project.
I can see the curves in the data view in SE and attached you can see the exported files.
But I used SE 3.5 (2009)
Maybe you can try the latest version of SE too in evaluation mode and try if you see a different behaviour then.
You can download the evaluation version here:
http://joule.ni.com/nidu/cds/view/p/id/1378/lang/de
Regards
DianaS
(6,773 Views)
(6,772 Views)
