SignalExpress
Cannot extract Patch_1.2.0.0001.exe
This patch is intended to add support for Signal Express User Defined Steps for use in both LabVIEW 8.0 and LabVIEW 8.2. Its filename is Patch_1.2.0.0001.exe. When I try to execute this file, however, I get a "header corrupt" error despite downloading it several times and on different machines.  Is there a problem with the patch?
(6,705 Views)
Hello Dazed,
National Instruments is already aware of this issue and it has been corrected.  I will let you know when the new patch is posted.
Janell Rodriguez | National Instruments | Applications Engineer
(6,692 Views)
Hello Dazed,
I just wanted to let you know that the new, repaired patch has been uploaded to the website.  You can still find it at the same URL.
Thanks!
Janell Rodriguez | Applications Engineer | National Instruments
(6,681 Views)
