SignalExpress
Cannot import TDMS data into Openoffice Calc ver 2.4.0
Is the TDMS Openoffice Calc Add-in Tool supposed to work with Openoffice ver 2.4?  I've downloaded the add-in and "installed" per the instructions on th NI web site, but "TDM Importer" never shows up in the Openoffice Calc menu bar.  Any ideas?
(9,202 Views)
How long ago did you download the TDMS Add-In Tool?  A new one was released on May 7th, 2008, that should now work with Open Office 2.4 (I just tested it).  Download it here.
Message Edited by Pakman on 06-03-2008 05:27 PM
(9,180 Views)
Just downloaded it 2 days ago.  Could Vista be causing the problem?  Geee, what are the odds of that!
I'll try downloading it again and re-installing it, but I don't expect any different results.
(9,175 Views)
Yep, it's Vista.  Sad news for both of you Vista fans (you know who you are, Bill Gates and your clone from the Apple commercial!)
I installed Openoffice 2.4 and the TDMS add-in on my XP machine and everything works fine.  I guess I'll have to wait for Vista SP2 or Openoffice 2.5 to use this add-in on my laptop.
My work-around is to save the data file as ASCII.  When you save the file, go ahead and rename it with a .csv suffix.  That way Openoffice Calc will recognize it as a delimited text file and takes you right to the "Text Import" window.  If you leave your save file with the extension .txt, when you try to open/import the file into Openoffice Calc, the file will open in Openoffice Writer instead.  Hey, it thinks it's a text file.
(9,165 Views)
I would agree with you N_Cooper, but I managed to install it on Vista as well.  Maybe you need to uninstall/reinstall OpenOffice?  Do you see TDMImporter.exe in C:\Program Files\OpenOffice.org 2.4\program?  Are you running any antivirus programs that would perhaps prevent files from installing completely?
(9,162 Views)
Pakman,
I took your suggestion and uninstalled Openoffice 2.4.0.  I re-installed the newest version, 2.4.1.  This time, before I installed the TDMS add-in, I disabled the Openoffice Quickstarter down in the Taskbar.  The add-in installation instructions tell you to do this, but I ignorred it on all previous attempts.  Bottom line, it works.  TDMS Importer show up in the Toolbar of Calc.
So, was it the updated version or disabling the Quickstarter?  I don't care as long as it works.
Thanks for the input.
nealbert
(9,106 Views)
