SignalExpress
Change trigger rate in SignalExpress, and perform Pulse Height Analysis
 OS: Windows VISTA
Software: LabView SignalExpressV2.5.1
Signal: random pulse from GammaRay Detector, pulse width: 1us-10us, Pulse Height:0-5000mV
I am trying to catch pulses sequence from Tektronix TDS1001B and perform analysis, I got problem:
1. Whenever the SE control the Scope, the trigger rate turns to 1Hz ro so, this is so slow, I lose the radioactive pulses.
2. I want to analysis the pulse height, and plot the accumulated counterates in512bins, how could I perform this in SE?
I need to counting the pulses continuously.
Thanks.
(6,155 Views)
Hello YRL,
1. For trigger settings look at the SE-Help. In the search register type in "trigger" and you get information about the trigger settings, which are available.
2. Sorry, but I think I didn't understand your question right.If you want to safe the data in a printable format, have a look here:
Importing and Exporting Data in LabVIEW SignalExpress
http://digital.ni.com/public.nsf/allkb/E07BB90F42D614CA862573ED006F65AC
To plot the signal in a XY-Graph have a look here:
User Defined Step to Create XY Graph in SignalExpress
http://zone.ni.com/devzone/cda/epd/p/id/3673
How Can I Create an XY Plot in Signal Express?
http://digital.ni.com/public.nsf/allkb/62729F5063C1C5E68625727C0067B815?OpenDocument
I hope this helps you out,
Markus
(6,098 Views)
