SignalExpress
Changing default values for DC offsets
I'm using LabVIEW SE 2012 on win7.  Is there a way to set DC Signal offset to be equal to the sum of another signal inputs offset plus a constant value (from a text or other?)
I want to be able to change the DC signal offset of one signal and have the DC signal offset of another signal automatically scale up.  I took two screen shots of the configurations for two Analog DC signals.  I want to set the Offset (V) of the Ag/AgCl signal and have the Pt Bias signal automatically set itself to that offset plus a constant (like 0.5).
Thank you so much.
Sheila
Message 1 of 1
(5,877 Views)
