SignalExpress
Circuit Examples
I had download the circuit examples from ni, but i cant run it cos i dont had setup ni tranditional daq, but i had to setup ni-daqmax, so how can i run, that program? want morething i have file setup of ni tranditional daq already, but my computer 64bit it cant install, so please common me.
(7,091 Views)
You're going to need to provide more details regarding what example you're referring to. Did you find it in the LabVIEW example finder? What was it's name? Did you find it online? Can you provide a link? Traditional DAQ is not supported on 64 bit.
(7,079 Views)
you mean the link of Circuit Examples, that I had donwload from IN?
https://lumen.ni.com/nicif/us/academicprojects/content.xhtml
(7,075 Views)
I'm not sure I understand the issue. Are you saying that the example requires traditional daq and you only have daqmx installed? If you're on a 64-bit machine and the example requires traditional daq you won't be able to run it on that machine. Please elaborate on the issue so I can assist you further.
(7,069 Views)
Ok, in traditional daq it has the function like AI read, AI start....., but I dont have of that functions, I try to find out, on NI web site I see that at there explain about Transition from Traditional NI-DAQ to NI-DAQmx in LabVIEW at https://www.ni.com/en/support/documentation/supplemental/06/transition-from-traditional-ni-daq--lega... but i do not understand. Other more at the example of circuit is to old version Last Modified: 10/25/2002. So I just want to know have any way to up to date of this example. or could you help me to transition from traditiona daq to NI daqmax? I also found this site say about this. https://www.ni.com/en/support/documentation/supplemental/07/transitioning-from-traditional-ni-daq--l...
Really thanks for your help.
Best Regard,
(7,066 Views)
That article is a great resource! It might also be useful to browse the example finder and look at the DAQmx examples. DAQmx is really easy to use (take a look at the DAQ Assistant Express VI) so I don't think you'll have any problems once you delve into it a bit. Let me know if you have further questions!
(7,057 Views)
