SignalExpress
Clipping Signal
Is it possible to clip a signal at a certain threshold value in SignalExpress? I have about 30 seconds of data that I would like to clip at mean plus-or-minus two standard deviations.
Akshay
Message 1 of 8
(7,729 Views)
Hello AkshayHari,
Look for the Limiter.vi in the SignalExpress\Examples\Tutorial directory. The Limiter VI accepts a time-domain waveform as an input, clips the signal above and below values that you specify in the Step Setupdialog box, and returns the clipped waveform as an output signal.
Eric  NI
Message 2 of 8
(7,717 Views)
Thanks for your help!
How exactly do I add that VI to my project?
-Akshay
Message 3 of 8
(7,713 Views)
Hello AkshayHari,
If you mean to add a VI to your NI Signal Express project, you need to right click the Project area, then "Run LabVIEW VI" and select the LabVIEW version of your VI and browse to it.
Eric NI
Message 4 of 8
(7,698 Views)
Hi Eric,
I tried the "Run LabView VI" option, but kept getting an error message saying "Please Select a VI to Open" even after selecting the VI that I wanted to open.
Akshay
Message 5 of 8
(7,696 Views)
Hello AkshayHari, is the VI compatible with the version of LabVIEW you select?
Message 6 of 8
(7,688 Views)
I tried all the versions of LabView that were shown as options.
Akshay
Message 7 of 8
(7,682 Views)
Hello Akshay,
Take a look at the following KB, it gives you some steps to have a VI working in SignalExpress
http://digital.ni.com/public.nsf/allkb/359D14941D6936E98625729D008387D5
Eric NI
Message 8 of 8
(7,676 Views)
