SignalExpress
Code Generation Error
I have Labview Development Professional 2016 and the included SignalExpress 2015. I am unable to generate code from signal express for any project. The error is:
"The version of LabVIEW you are generating code into does not contain all the necessary SignalExpress support files. Make sure you launch the version of LabVIEW with SignalExpress support installed before generating code from SignalExpress. If you installed this version of LabVIEW after SignalExpress just re-run the SignalExpress installer to install the necessary support files."
I have tried to do as others suggested by downloading and reinstalling SignalExpress - with no luck.
Any other suggestions?
(7,294 Views)
Hey,
So I have a few thoughts on this. SignalExpress 2015 has some limitations listed in this document.
https://www.ni.com/en/support/documentation/bugs/15/signalexpress-2015-known-issues.html
One limitation that could be causing you problems is if you are running 64 bit LabVIEW, SignalExpress will not generate code.
As for next troubleshooting steps if you are not using 64 bit LabVIEW would be to try a repair of the SignalExpress software or doing a Force Reinstall
Repair NI Software Link:
https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
Force Reinstall NI Software Link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
Please do the force reinstall after trying all of the other troubleshooting, as this is the most involved process. Hope this helps!
Spencer R | Applications Engineer | NI
(7,270 Views)
Though I am running the 64 bit version of Windows 7, I do have the 32 bit version of Labview.
Neither the repair nor the forced reinstall has solved the issue. I can't think of anything in the projects themselves that could be causing this as the tutorial project for exporting code also fails to export its code.
(7,247 Views)
Perhaps there was an error when installing LabVIEW 2016? Maybe the support files were not included. You may want to try doing a force reinstall of your LabVIEW version. Perhaps that will help fix the support files for Signal Express. Good luck!
(7,215 Views)
