SignalExpress
Continuous data capture, single point logging
Hi ShalimarA,
Yes, I did that. I removed them all, and then added one at a time, running the project each time after I added a channel. It made no difference, they still logged to file in the wrong order.
Bandit.
Message 11 of 32
(3,533 Views)
I thought so, I just thought it would be good to cover all eventualities!
I'm looking into this right now, trying to replicate the problem. The project you've sent me doesn't have triggers, was this something you removed?
ShalimarA | CLA
Message 12 of 32
(3,530 Views)
No software triggers? Pah. I may have uploaded the wrong thing then.
I'll look into it on Monday, see if I can send you the correct file. Right now I'm afraid I have to leave, it's the end of the working day here and I have comitments that prevent me from staying late tonight.
Thanks for your help so far, have a great weekend.
Bandit
Message 13 of 32
(3,528 Views)
I'm beginning to wonder if this is something specific to your version of SignalExpress as I'm running the 2012 version and can't seem to replicate the issue, everything is coming out fine. I'm going to be trying it on version 3 now.
ShalimarA | CLA
Message 14 of 32
(3,528 Views)
Have a good weekend!
ShalimarA | CLA
Message 15 of 32
(3,525 Views)
Hi ShalimarA.
This morning I have checked the project example I uploaded last week. The start and stop conditions for logging are definatly set up for software trigger A. This is shown under the recording options tab, under the start conditions and stop conditions catagories respectively.
I have also tried running the project under Signal Express 2011 (I don't have a 2012 installation at this time). The log was created but again the channels were logged out of order.
Hope this helps.
Regards.
Bandit.
Message 16 of 32
(3,518 Views)
So sorry for the delay, I've been out of office recently.
I've realised that we hadn't isolated something relatively important. As the data comes out fine for me, you'll need to confirm. Is it that the data as well as the channel names swapped around? Or just the channel names?
I ask because if it's just the channel names that are swapped around, for example channel a01 has the data associated with ao0 if it's listed first in the log list, then that could indicate something being wrong in signal express.
If it's that the channels and their associated data are in the wrong order, this could signify some sort of data corruption.
ShalimarA | CLA
Message 17 of 32
(3,507 Views)
Hi ShalimarA,
We did cover this already, in message 4...
"I acquire and process channels in the order AI1, AI2, AI4, but the columns in the log file are ordered AI2, AI1, AI4.
Column headers are correct with respect to the data below them, it's just that the columns are not ordered as expected.  "
To clarify that further, with channels generally held at 0v if I apply 5v to individual channels in turn I get a log that looks something like this...
AI2    AI1    AI4
0V     5V    0V
AI2    AI1    AI4
5V     0V    0V
AI2    AI1    AI4
0V     0V    5V
I hope this helps, if it's still not clear please let me know.
Bandit.
Message 18 of 32
(3,501 Views)
Sorry about that, but thanks for explaining.
I've just tried running the code and adding an extra step that saves to an ASCII/LVM file. This worked and put the data into ordered columns. Do you want to give this a try and seeing what it does for you? This would be getting rid of the in built logging function that you're currently using and executing it otherwise. (See attached image and log file)
ShalimarA | CLA
Message 19 of 32
(3,496 Views)
But how does this log a single data set on command? It looks to me like it logs all the data captured, not just the particular user selected moment of interest.
Bandit.
Message 20 of 32
(3,490 Views)
