SignalExpress
Covert displacement sensor (mm) to speed (mm/s) in sound vibration assistant 2010?
Can you covert a displacement sensor (mm) to speed (mm/s) in sound vibration assistant 2010?  I know you can use the vibration level block to integrate and go the other way from speed to displacement, but I can't seem to find a derivative block for going from displacement to speed.
(5,983 Views)
This is not a native function to signal express S&V assistant.  You could divide by the sample period time using an arithmetic function to get a rough shot at the derivative.
Best,
Adam
Academic Product Manager
National Intruments
(5,969 Views)
