SignalExpress
Edit X-scale display format of waveform graph
Hello everybody,
I set the X-scale display format of waveform graph to absolute time. I want to set the date and time based on other data. can i set? If i use property node [minimum, maximum], i cannot set the string. Can somebody help me? Thanks in advance..
(7,364 Views)
Hey Treasure,
Are you using LabVIEW or Signal Express?
So are you planning to dynamically change the way the X-axis displays data? Or is the format going to be constant?
Do you want to change the scale of the axis?
Also, you might get more response if you post this in the LabVIEW forums.
Aashish M
CEO
TransferFi
www.transferfi.com
(7,345 Views)
Good morning all
I have the same problem. I want to change my x scale of my data block in labview. I want that my horizontally scale is the same that my scope horizontally scale. I hope to modify this scale for to display the time in ms or other but i don't want the sample number are display on my graph. If you are an help to bring me thanks you in advance.
I'm a french study in microelectronic in Tours
(6,321 Views)
You are posting duplicate threads all over the place - here, here, here, and in here in the SignalExpress board. None of these boards are appropriate to your LabVIEW question. None of your code makes much sense to me since I never use the instrument i/o assistant but you have dataflow problems. Your write data to the graph in parallel with writing to the property nodes. Using plain LabVIEW, if you used the waveform data type, the graph would not require setting the scale with the property node. What model of scope are you using? Have you looked for an existing driver (Help>Find Instrument Drivers)? Have you looked at any of the existing scope drivers to see how the data should be formatted (and without using the assistant)?
(6,317 Views)
I use a tektronix tds5054 scope. I receive on the horizontally scale the number of sample while i want the time base. Without nodes properties the curve correctly display in my graph but the scale horizontally is not appropriate. I have already installed the equivalent driver for my scop but i can't converted my dynamic data.
Thanks you for your answer
(6,307 Views)
