SignalExpress
Error -200361 occurred at DAQ Assistant
Hello
I got the problem in signal express but i don't know why it happens ??
i am able to acquire the signal using analog output channel zero but problem is that after recording one or two signals then it showing ERROR message like
Possible Reason(s):
Measurements: Onboard device memory overflow. Because of system and/or bus-bandwidth limitations, the driver could not read data from the device fast enough to keep up with the device throughput.
Reduce the sample rate, or reduce the number of programs your computer is executing concurrently.
If i go for the reset the channel then that provlem is solved.
i have attached snapshort also may be easy to solve it
so please give me the solution of it
(6,464 Views)
what hardware/DAQ card are you using?
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(6,457 Views)
thank you for reply it,
Yes Sir, My Hardware module of DAQ card is USB 6009
Signal Express 2009
Win 7 Professional
but sir i counld n't get it what you want to convey the message using those sentences
PCI 6281 DAQ card
(6,451 Views)
Take a look at this KB http://digital.ni.com/public.nsf/allkb/611475F9BE62881E86256FDC0062B1BB
...and nevermind the details at the end of my posts. Its just a list of the hardware and software I use.
Keeps me from having to including those specifications when I need assistance on the forums.
PCI 6281 DAQ card
Win7 Enterprise
(6,443 Views)
