SignalExpress
Error #50251
I am trying to take some ambient vibrations using an accelerometer connected to a NI 9234 DAQ through a chassis  NIcDAQ-9117. When trying to run Signal Express I get error code #50251, which says is at the DAQ Assistant and due to the specified software not being available.
when I run a test panel in NI-max it further says that Error#50251 occurred at "daqmxcfg_DAQmax Start Task.vi:4410001.
I am have Windows 10 in my computer.
I appreciate any guidance on what to do. I am new at using the software (and hardware) so my apologies if I am not formulating the question properly.
Paul
(4,374 Views)
Hi there,
Have you downloaded the DAQmx driver and installed the support for SignalExpress? You should be able to install it and then when the splashscreen pops up for additional support (you can select LabVIEW, LabWindows™/CVI, SignalExpress, etc), turn on the support for DAQmx and SignalExpress and you should be good to go.
Thanks.
Aulia V.
(4,334 Views)
Thanks very much for the help!
I used the instructions provided in the link below to repair the drivers of DAQmx.
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Problem solved!
(4,327 Views)
