SignalExpress
Error in SignalExpress2.5 when using cDAQ-9172 with 9233 and 9215
I connect a NI9233 (acceleration) and NI9215(voltage) within a cDAQ-9172 to use with with SignalExpress 2.5.
When starting data acquisition the following error appears on one of the devices (ramdomly one of the devices):
Error - 50103 occured at DAQ assitant
Possible Reason:
The Device is reserved.
Each device works for itself but not together.
I can't find any hint or description how to solve this problem.
thx in advance for any suggestion
Stefan
(6,256 Views)
I found out that i have to add just one DAQmx Module e.g. 9233 and aktivate the second one (9215) in the channel settings of the 9233 and not adding 1 DAQmx module for each device.
Now it's working.
Stefan
(6,237 Views)
