SignalExpress
Graph power over time
I am new to Signal Express.  I am using it with the USB-6289 to measure system power on my DUT.  I have a target sense resistor on the board that I have sense lines connected to and thse lines are connected to analog 1 and analog 2 on the 6289.  The goal is to measure the voltage drop across the resistor and use it to calculate the power and graph it in real time with Signal Express.
I created a task for voltages ai0 and ai1 for the voltage drop across the resistor.
Tried to run the project but I am not seeing any kind of output on the screen.
I verified the 6289 is being detected and calibrated with NIMAX.  Also created a task with NIMAX.  However, I am not sure how to specify power over time.  How do I specify power over time in Signal Express if I have sense lines connected to a resistor on a board?
Thanks, Joe
(5,994 Views)
Hi Joe,
Are you able to run and see the voltage in MAX when you create the task? How do you have your voltage input set up in SignalExpress?
Here is a link that might be helpful for setting and collecting data in SignalExpress: http://www.ni.com/white-paper/5903/en/
As far as calculating the power over time, you can create a customer scale. Here is: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH6OCAW&l=en-US
Thanks!
Stephanie S.
Application Engineer
(5,971 Views)
