SignalExpress
How can I resample the data I have already acquired?
Dear All,
I have my data acquired at a rate of 50Hz and but this gave me too many data points for me to be able to export to an excel file as it exceeds the ~65K maximum set by excel. I have the data saved in a signal express file, and can I resample it somehow inside the signal express software to decrease the number of points I have.
Thank you Zsolt Zador
(6,327 Views)
Use the subset and resample block.  It should do exactly what you want.  Note that newer versions of Excel will let you go over the 65k limit older versions had.  Export to ASCII to take advantage of this.
Message Edited by DFGray on 07-29-2008 08:39 AM
(6,322 Views)
