SignalExpress
How can you post comments during signal aquisition?
How can you post comments during signal aquisition? For example, while acquiring your signal, you want to post a comment which the temperature reads at "30 seconds" from your relative start time (t=34 sec into recording)
I have the LE package where events, alarms, etc cannot be used. Are there other ways that the user can mark an "event" during recording?
(5,564 Views)
Hey hkim,
If you know how long it will be before you want a message to pop up you can simply include a sequence structure and in the first sequence have a wait time of your desired length and have the message pop up and display in the second sequence frame.
Hope This Helps,
Doug B
(5,559 Views)
