SignalExpress
How do mesuare Force with loadcell VLC 110S used USB NI 6009
And i want measure Tension/compression force.
Help me please! thank you.
(5,980 Views)
Hi, I recommend cheking this forum thread. In summary, the 6009 can't read directly from the load cell but if you built your own external signal conditioning circuit it will make it possible. I hope this helps
Alejandro C. | National Instruments
(5,965 Views)
