SignalExpress
How do you export LabVIEW SignalExpress Log files into MatLab?
I am using SignalExpress to capture vibration and acoustic data.  I need to show the results to a customer that doens't have access to LabVIEW.  They have Matlab, so I need to find a way to export the SignalExpress log file into a usable format that I can import into Matlab.
(6,786 Views)
SignalExpress log files are in TDMS format.  You also have the option to convert your log to text when you finish it.  So you have two options:
  1. Send the original TDMS log and have your colleague use the MATLAB plugin which allows reading of TDMS files.
  2. Convert the log to text and send the text files.
The first option is probably your best bet, since it will result in smaller files.  Let us know if you run into issues.
(6,770 Views)
