SignalExpress
How to accelerate the processing
I have data recorded at 2000s/sec for some hours.  Now I want to analyse the data eg taking a average of every 2000samples (1sec). After playing with the options (no delay, no update of screen).still SE takes a lot of time to display the new graph with the mean values (project contains this single processing step).  If I do this in LV --> much faster.
Question: is this related to the principle of SE or do I something wrong?
Second question: what is the easiest way to extract portions of data out of my big set.  I want to re-use these portions further in SE.
Thanks for feedback
(6,679 Views)
When you said you set no delay did you mean changing the playback rate to "As Fast As Possible" from the Edit menu?
(6,657 Views)
