SignalExpress
How to get power spectrum manigtude at the first harmonic
I use PXI 5122 to capture signals from (2) channels 0-1.Channel One output of my device is 1Mhz and a adjacent channel should be very low signal due to cross talk.   I use power spectrum VI but it does average power sprectrum. I would like to extract just the magnityude
at 1MHZ ( fundamental component od my output signal) in frequency domain.
Per attched graph, I want the different in dB between two signal 1 and 2. Instead of reading off the chart is there a way
to extract that single component magnitude.   See attched VI and frontpanel for referecence.
Thanks for your help.
(6,653 Views)
forgot one more attached .
(6,652 Views)
You can use Peak Detector.vi to find peaks in a signal.  Better yet, use the Extract Multiple Tone Information.vi to get the power spectrum and a list of peaks in one operation.  Extract Multiple Tone Information.vi will do a better job, since it does a peak fit and will return subsample accurate information.
(6,638 Views)
Thanks for your reply.  My output is a cluster I cannot wire to extract multitone info vi.
see attched vi (8.6).
(6,630 Views)
I forgot to tell you that I already use this extract tone VI. But it give anplitude in volt which is not what I want.
 I want to get the peak of the 1st hramonic in dB , from the power spectrum cluster as mention in the first post.
(6,628 Views)
I found the answer. I just have to split the cluster of power spectrum output into two and search for max value. Thanks
(6,619 Views)
