SignalExpress
I want to create a clipped signal
I am using signal express to read field recordings, do signal processing and then playback this data. Part of the signal processing that I want to do includes clipping the signal. Is this possible with signal express?
(5,718 Views)
This functionality does not exist natively in Signal Express.  However, you could create a custom step to perform the clipping using LabVIEW and then call it in Signal Express.
-Christina
(5,701 Views)
