SignalExpress
I want to export data from excel sheet to system identification toolkit am unable.please help me
I want to export data from excel sheet to system identification toolkit.I am unable.please help me.in the import option i am getting aquire,load from lvm files but i can't import data from excel sheet.
(6,246 Views)
SignalExpress based applications cannot read data directly from an *.xls or *.xlsx file.  You must first export the data to a text file.  In Excel, save the file as a *.txt file with tab separators (should be the default).  Then read the file in the SysID toolkit using the import from ASCII step.  If you run into problems, let us know.
(6,241 Views)
