SignalExpress
Is it possible to have a very low log rate ie 4hours with Signal Express?
Also are there drivers for Solatron Imp modules?
(6,868 Views)
Hi!
I hope you are doing well today! Yes, it's possible for you to have low log rates. In your rate, just enter 6.95e-5 which is 1/(4*60*60). Also, it seems like we do have some drivers for Solatron at idnet.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(6,857 Views)
Thanks for that:)
Unfortunately the Solartron units we have are the 3595 Imp modules and there is no mention of drivers for that unit.
Thanks again tho!
(6,848 Views)
In that case, you will need to contact the manufacturer of the deivce. If you are unsuccessful with that, have a look at the other drivers; most of the I/O and function calls should be the same.
Adnan Zafar
(6,841 Views)
