SignalExpress
Is it possile to plot amplitude vs rpm?
Hi!
Is it possible to plot measured vibration signal against rpm obtained via analog tacho processing (speed profile)?
Like this:
Thanks!
(5,531 Views)
In this situation, I would try using the XY Graph for your plot. With XY graph you simply feed it a set of x and y values and it will plot that for you. For your case, you can just feed it your set of vibration signal data and RPM data and it should plot it for you. I have linked our help page on XY graph to give you some more info on how it works (It's about halfway down the page).
Link: http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/types_of_graphs_and_charts/
James F.
(5,489 Views)
Hi!
I don't uderstand how to take Y from speed profile to feed XY graph. Can you try to do that on my data? (see attached, Voltage2 - analog tacho, scaled signal 1 - vibration signal from proximeters)
Thanks!
(5,454 Views)
If you are using the Sound and Vibration Measurement Suite, there is a Bode Plot graph, with examples.  This plots vibration versus RPM and is useful for identifying machine resonances.  If you have the Sounda and Vibration Measurement Suite, look for the bode plot example.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(5,451 Views)
Thanks for the answer. I have sound and vibration toolkit but bode plot is not suitable for my purposes.
P.S. I found two more problems with signal express:
1. How to plot full vibration signal after filtering? It plots only period of time.
2. How to plot anything in a certain moment (orbit for example)? Should I "catch" the right moment while it starts drawing (after I press <run> button)? Is it possible to plot graphs step by step or in certain moment of time?
Thank you!
(5,408 Views)
The article linked below shows how to do an XY graph in signal express. As for the other 2 questions you had, I just want to clarify and make sure I'm understanding it correctly. When you say it only plots period of time, are you saying it is leaving out part of your data? If that's the case you should be able to just edit the scale on the x-axis to show the full period of time you were collecting data.
For the second question, I'm not sure I understand what you are trying to do. Is there an event happening at a particular time that you are trying to capture? Perhaps triggers would be appropriate here.
Link: http://digital.ni.com/public.nsf/allkb/B82BFECDB98774BB862573B400799846
James F.
(5,389 Views)
