SignalExpress
Joint time frequency analysis in Signal Express?
Is it possible to do joint time frequency analysis in Signal Express?  I didn't see it in the Analysis section, so I'm assuming it's a separate tool that has to be added, if even possible in Signal Express.  Help?
(5,819 Views)
Accepted by topic author TimRsandiego
SignalExpress does not natively support joint time frequency analysis.  However, check out the Sound and Vibration toolkit which expands upon SignalExpress.  It may do what you want.
(5,810 Views)
