SignalExpress
LabVIEW Signal Express DAQ Assistant Error
Trying to get more information on a DAQ assistant error.  We are using LabView Signal Express 7 for data collection in an MRI scanner.  The DAQ Assistant error keeps on popping up randomly and costs us precious scan time.  It only occurs when we hit 'Record' or 'Run Continuously'.  It does not occur every time, but often enough to pose an issue. Thanks for any help.
(7,071 Views)
Hi Carpensa
Which error code are you getting? Which is the configuration or the setup of your task? Could you some more screenshots with the error code, configuration or even attach your code?
Which device are you using to acquire the data?
Regards
Esteban R.
(7,053 Views)
________________________
Enjoy high quality http://www.sutradvd.ca/true-blood-season-5-dvd-boxset-free-shipping-p-2092.html True Blood Season 5 DVD and fast delivery.
(6,915 Views)
