SignalExpress
LabVIEW SignalExpress - Error Message
When loading a project file that was recorded and saved via a USB-9215A device on a different PC, SignalExpress 2.5 (limited edition) gives me the following error message: "The step encountered an error while loading.  Please install the latest version of DAQ Assistant components" What would I need to do to fix this? In browsing the NI-DAQmx CD that came with the DAQ device, I did not see anything that pointed me to "DAQ Assistant components" Thanks.
(6,441 Views)
It sounds like your two different PC's have different versions of NI-DAQmx. The one that you create the project file on sounds like it has a newer version than the one you are trying to load on.
The "DAQ Assistant components" is the DAQ step you used in SignalExpress, which gets installed with NI-DAQmx.
Phil
(6,439 Views)
