SignalExpress
Labview Vi
Hello, new here.
I am trying to use a isolation module (DI-1000-TC) to monitor thermal couple temperature on signalexpress under Labview 2014 Vi. I cannot get signalexpress to detect there are any channels active. I can add the channels into signalexpress labview but they are in volts not is C as in Celsius.
I am using WinDaq Lite data Acq program to view the thermal couples which I can see the temperatures
This was always a working process. Dont know if its a drivers issue or a update problem.
Message 1 of 1
(3,832 Views)
