SignalExpress
Large display for real signals
Hi everyone
I would like to show the values of my signal with a large display.
I have Signal express 2011
It is possible to do so?
Do I have to convert the signal to other format, Double?
Thanks in advance
Signal Express 2011, WinXP, NI PCI 6221, Ni cDAQ 9174, Ni 9235
(5,781 Views)
You can use a digital display to show a simple numeric of your data, assuming your data is a scalar.  If it is a waveform, you can either show it in a table (probably not what you want) or run it through a step, such as Amplitude and Levels, which extracts a scalar measurement from your waveform data, then show it or a digital display.  You can change the type of display by right clicking the viewer, selecting View As and picking what you want.
(5,778 Views)
Hi DFGray
Thanks for the help.
Finaly what I did to change the type of signal from Real time to Double was to choose Samplers on Demand instead of continuos Samplers. I put a sample period of 100mSec and then I was able to use the visualize the signal in a large display. Anyway I will try to use a step of amplitudes and levels as  told me because it can be usefull for my test too.
Thanks again.
(5,768 Views)
