SignalExpress
Multiple signal types in one chart
Hi there!
I need some help to understand if it is possible to do what I intend to do using SignalExpress LE.
The task is actually quite simple. I need to start a measurement of 2 analog, 2 digital and 1 frequency channels. The sampling speed is moderate, 5kHz. During logging I wish to be able to see the signals "live" and afterwards I want to compare signals and measure time between signal events in the graph.
I tried with a simulated device (since I have not yet one), the USB-6211. This failed due to the model only being able to poll the frequency channel (I think so since I was not able to select continuous samples). Therefore I tested by simulating with USB-6341 and made this setup:
Test setup
Now I have some questions:
  • Are the steps (on the left) performed in sequence or in parallel?
  • Can I plot all signals in one graph so I can correlate them and zoom and measure all together?
  • I wanted to log the signals but I couldn’t include the frequency channel (see the little dialog box). Shouldn’t that be possible?
  • I’m also confused by the fact that the frequency plot has Volts on y-axis and not Hz.
  • Do I really need HW timing on digital I/O to perform this “simple” task? Which means a more expensive HW…
Many thanks for any input!
Nicke
Message 1 of 1
(5,630 Views)
