SignalExpress
NI 9205 card is not recognized by MAX
Hello
I am using MAX version 15 for labview 2015. The program is used for controlling fans, spark ignition and reading temperature and pressure. 5 NI cards such as NI 9205 are used in the DAQ system. After doing an experiment, the labview gave me an error " 201003 occured at DAQmx create channel (AO. voltage. basic).vi ".
For trouble shooting, I openned MAX and found that card NI 9205 has a small x and turned to be not recognized. I checked from Devices manager-DAQ and it showed me that all other cards are detected except Ni 9205. I tried to restart and turn the pc on and off, reseat the card, seat it in another slot but still it wasn't recognized. I seated a working card on the same slot of NI 9205, the working card was recognized.When I do a test for the other cards it gives OK, while for Ni 9205 thee options are in grey colour and test is not available. It seems that whatever I do, NI 9205 wont be recognized. Is it damaged? I hope not.
Thanks a lot for any help
(6,035 Views)
Accepted by topic author ayache
Take a look at this knowledge base article.
Error 201003 at Test Panel in MAX or While Running DAQ Assistant
http://digital.ni.com/public.nsf/allkb/5413F392D88326148625746B006745C5
Let me know if this is able to resolve the issue, otherwise we may have to save your configuration and reset the MAX database.
Finch Train
(5,997 Views)
Hi Finch Train
Thanks a lot. I followed the same steps before and I also contacted a senior engineer. The card is unfortunately damaged.
Thanks again
(5,993 Views)
