SignalExpress
NI Labview Signal Express activation dont work
Actually, signal express was working properly. We tried to run the upgradation cd on 4 Jan, 2010 that was provided by NI in august 2009. It was taking unexpectedly longer time and we turminated running the setup before completion. When we start signal express a window appeares that ask for activation (see attachment). Even after activating properly, same window appears time and again. We are unable to start signal express, please do the needfull.
(5,919 Views)
Sounds like aborting that installation may have corrupted your software. I would try to repair Signal Express with the original disks that you had and see if that works ok before trying to install the upgrade again. You can repair NI software by going to Add/Remove programs, find National Instruments Software and click Change/Remove. This brings up a window where you can select Signal Express and click the repair button. It will probably ask you for the CDs that you installed from ( the original CDs). Let us know how this goes, if you have problems or questions we will try to help.
(5,890 Views)
