SignalExpress
No Chrip or MLS in SV Assistant?
Can Chirp and MLS signals be referenced/created in the Sound and Vibration Measurement Assistant?  I own SVMS.  I use them in LV.
(5,730 Views)
are you talking about creating a chrip wave to do a frequency sweep with? If so you can probably just create a multi-tone analog input. I don't think that SVMS has a native MLS signal generator. But you can always import your own wavefiles from ASCII, LVM, or UFF58 file formats.
Gabriel M.
Product Marketing Engineer - Academic Courseware
(5,703 Views)
"Load Signal" looks like the solution.  That feature will allow me to import my Chirp and MLS stimulus signals.  Sound and Vibration assistant has a bit of a learning curve, but it's worth the effort.  I prototype the measurements in S&V Assistant then transition them into LabView.
Thanks for the guidance.
Noel
(5,696 Views)
