SignalExpress
Plotting IVI Power Supply voltage
I am usint SignalEpxress to control to my Agilent N6700B power supply, and I am successfully commanding the instrument and querying the output voltage.
However, I can't seem to figure out how to plot the output voltage on a strip chart. The 'IVI Power Supply' step only seems to offer two output options:
'over-voltage tripped'
'over-current tripped'
It doesn't therefore seem possible to hook the output voltage of the step to a data view strip chart. Any ideas on how to accomplish this?
Aaron
(5,906 Views)
I don't think you can do that with IVI in Signal Express. You could try instrument control step to query a command to power supply instead.
(5,897 Views)
@astibich, just out of curiosity, can’t you accomplish the same in software. Since you’re getting the required values of voltage, you can plot that within the PC. If required these values could then be transmitted to a real-time plotter as well. If you’ve already found a better solution to this, I’d love to know, just for information. It’s the ingenious ideas of people that actually inspire me, like everyone else, to think outside the box.
(5,565 Views)
