SignalExpress
Read wav file
Hi all,
is it possible to read a wav file and then process it ??
pollon
Message 1 of 8
(9,319 Views)
Hello pollon,
is LabVIEW the software you would like to use? If yes, it is possible:
How to Use the Sound Output VIs in LabVIEW to Play Wave Files
http://digital.ni.com/public.nsf/websearch/1BE60DBBFA22ACC186256DFB000B8464?OpenDocument
Is this what you were looking for?
Saluti,
Antonios
Message 2 of 8
(9,312 Views)
thanks for your support. Anyway I would like to read the wav file with signalexpress and then process it with the sound and vibrationj toolkit
pollon
Message 3 of 8
(9,305 Views)
Accepted by topic author pollon
I leave an example which can contribute, Greetings
Message 4 of 8
(9,068 Views)
Message 5 of 8
(9,062 Views)
i hav labview11 i cant run this vi in labview11 is there any way of opening labview12 files in labview11
Message 6 of 8
(9,008 Views)
If you want to open @ltheux's example, don't bother. The sound file examples that come with LabVIEW are better.
Message 7 of 8
(8,994 Views)
I'm having trouble with playing a wav file.
What I want to do is playing the sound when a boolean originating from a FPGA target is True.
Although I try to play the sound on the top level VI (runing on the computer) I get an error saying that it is incompatible with the current target.
A dummy copy of what I aim to do, but without FPGA target works well.
Hence I've also tried to 'isolate' the FPGA by playing the sound in another VI that talks inderectly to the FPGA via some global variable - but whatever the configuration I tried it would not work.
What is the reason why the computer is unable to play a sound as soon as it is interacting with the FPGA?
Is there a way around it?
Thanks!
Message 8 of 8
(8,096 Views)
