SignalExpress
SE 2.5 Bug?
In an earlier post, I was asking about some strange SE behavior when trying to delete log files.  I couldn't get them resolved, so I just started from scratch and recreated the project.  Everything was working fine untill I tried to add a Limit Test.  The step adds ok, but when I try to change the source for the limit SE crashes.  I have tried it about a half a dozen times with the same effect.  My processor usage goes to 100% and SE becomes unresponsive.  I have attached the project just prior to adding the limit step.  Could someone open it and see if they have the same problem?  Is this a bug that is already known?  Is there a work around?
Thanks everyone for monitoring this message board!!
JB
(7,446 Views)
We have reproduce the issue that you are seeing and we are working on a fix.  The good news is that it is not a hang.  After a really long time, about 4 minutes, SignalExpress will finish what it is doing and everything should be fine.
To work around this issue you can right click on the signal that you want to perform the limit test on, and select Send To >> Analysis >> Test and Compare >> Limit Test.  This will prevent the need to switch the signal that the limit test is processing and you will not experience the slow down.
I will look into your trouble with deleting logs today and hopefully get you an answer for that as well.
(7,431 Views)
Thanks Chris,
I have followed up on this in the "Trouble deleting log files" thread.  Since I think these two items are probably related, lets just use that thread so it is easier for folks to follow if they have similar problems.
Thanks again,
JB
(7,421 Views)
Just for clarity, I have linked to the post mentioned: Trouble deleting log files.
Mark E.
Precision DC Product Support Engineer
(7,410 Views)
