SignalExpress
Signal Express 2012/2013 no selection from the context menu after pressing the right mouse button.
My context menu has stopped working in Signal Express.
When I press the right mouse button on the graph/chart window (Data View), the context menu pops up,
but I cannot make a selection on this menu. This only applies to the area with charts.
Instead of an arrow to choose from the context menu, I have a cross and the selection field cannot be activated.
I reinstalled the software and the problem persists. Is it related to a badly activated license? (SE 2112/2013) Is it a windows error (win10). So far, everything has worked perfectly.
(4,181 Views)
I'll just want to bump this question as I'm experiencing the same issue.
My first thought was that it was related to the update of NI MAX to version 17.0, but now I'm not sure.
Did you manage to solve the problem aciesz?
(2,990 Views)
SE 2015 is acting evaluation version in the same way.
I have it installed from years on a computer with win8 and it is working fine (full, purchased edition).Please inform if you find any solution to this issue.
(1,957 Views)
