SignalExpress
SignalExpress 2.0 on XP Tablet PC Edition
I searched in the NI forums, and I found some threads saying that LabVIEW works on a XP Tablet PC Edition.
But what about SignalExpress?
I installed SignalExpress 2.0 over my Tablet PC (Samsung Q1), but when I try to launch the program I can see the splash screen, but then there is the following popup message:
Initialization Error
LabVIEW SignalExpress is not installed.
Please install LabVIEW SignalExpress before running the application.
Can anybody help me?
Tks
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(7,477 Views)
Hello Vix,
I suppose there aren't differences between LabVIEW and Signal Express Compatibility on your Samsung Q1. Did you already perform a repair of the Signal Express installation? You can also try to upgrade your software at least to the 2.5.1 version so you could fix your problem.
Matteo
(7,462 Views)
I'm sorry, but I don't understand what do you mean with this sentence. Could you explain it?
Yes, but it didn't help
I know I could try, but I'm not interested in it. I can activate a full licence of 2.0 version because I bought a LabVIEW 8.2 Full Development System, but I have to pay if I want a full licence of SignalExpress 2.5. I asked to a NI vendor, and he told me SignalExpress upgrade is not possible for free. Could you confirm this?
Tks
Vix
Using LV from 7
(7,447 Views)
Hi Vix,
I mean that both LabVIEW 8.2.1 and Signal Express 2.0 would be supported on Microsoft Windows Tablet Editions. Could you report exactly the software you installed on your Samsung Q1? Did you perform the licensing procedure correctly? According to the error you attached, it seemed that something wrong occurred during the software installation. Anyway you could download the latest Signal Express version (3.0), install it in evaluation mode and verify if you could reproduce the same warning.
Please let me known how it works.
Regards
Matteo
(7,440 Views)
Accepted by topic author vix
I had to update all NI drivers and components using the DAQmx 8.6 CDs instead of the DAQmx 8.5 ones (supplied with LabVIEW 8.2.1).
I didn't install the SignalExpress 2.5 from this CDs, so I'm able to use the 2.0.
Vix
Using LV from 7
(7,418 Views)
