SignalExpress
SignalExpress IVI acquire issue
I've recently upgraded from Signalexpress 3.0 to 3.5. Previously I used IVI acquire to get data from my multimeter, but since the upgrade, the option "IVI acquire" under "Add Step" has dissappeared, and I'm fairly sure (although not certain as I havent used many of the other options) that some other options have dissappeared as well. I've tried re-installing my IVI drivers and re-installing anything else I can think of that could be related, but it hasnt fixed the problem; all I'm left with are steps involving NI-DAQmx, which isnt particularly useful in this case.
Does anyone know if I simply might have missed re-installing something, or if there's something else I need to upgrade to get IVI acquire back?
(5,768 Views)
Are you sure you're running a fully licensed/registered version? You may need to check "Show Unlicensed Steps" in the Options window.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,760 Views)
