SignalExpress
SignalExpress TE Very Slow Getting Signals
Hi All,
I dug into the programming manual, and as long as you have your measurement fields preconfigured in the TDS1002B, you can poll them significantly faster than the supplied driver VIs.  I was able to poll all three measurements in 0.650 s, whereas doing a serial read on all three via the drivers took ~3.50 s.  Here's the VI that I used to do this.
Cheers,
Brian
Message 11 of 12
(3,022 Views)
Also, try to adjust your vertical range so the signal nearly fills the screen.  This will take better advantage of the oscilloscope digitizer, and I found that this increased the speed of taking measurements programmatically.  (600 ms --> 400 ms)
Message 12 of 12
(3,021 Views)
