SignalExpress
SignalExpress skips the import dialog for sgl tdms
If you try and import a TDMS file made from LabVIEW containing a single precision waveform into signal express using the import feature, signal express skips the "Convert Non-SignalExpress TDMS File" dialog.
Here's example code to make the TDMS file:
Message 1 of 8
(5,943 Views)
Hello nanocyte
I have tried both double and single precision float tdms files and both have worked fine.  have you tried changing the folder or name?
Diego H
Message 2 of 8
(5,889 Views)
Did you try the TDMS file I attached? I'm using SignalExpress 2015. How about you?
Message 3 of 8
(5,887 Views)
First I just Tried your code. and it worked fine.
But with the attached file it does not work you are right. Have you tried changing the name?
2015 as well.
Message 4 of 8
(5,874 Views)
Weird. So my LV2016 is broken? That's the file I get out of that code. It opens fine in the labview TDMS file viewer
764 bytes SHA1: c63ef05e5a4dde2b1de6b0f7250149cc29f80c80
Do you get some other file?
Yes, I tried rename and got stuck at "importing logged files".
Message 5 of 8
(5,868 Views)
It could be LV or SE.
You can try repairing first.
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Then force reinstalling to see if you are able to import the tdms file.
http://digital.ni.com/public.nsf/allkb/ADD22E807D5A12AD862579EC00760F79
Diego H
Message 6 of 8
(5,861 Views)
Can you do me a favor and post the file that you get when you run my code? Also, you're running LV2016 and SE2015 right? I want to test your file against my SE2015 to help figure out which is the problem
Message 7 of 8
(5,857 Views)
Sure.
there you go.
Message 8 of 8
(5,846 Views)
