SignalExpress
Solution for converting the UFF58--->UFF58b or UFF Ascii.
Dear all,
Rightnow, I'm working on vibration analysis by using LV signal express 2010 which seem can be exported the measurement file as the UFF58. (Universal File Format)
but my problem is; I have to use this measurement file with another program which accept only the UFF58b and UFF Ascii format.
I try to find solutions for convert UFF58--->UFF58b or UFF Ascii.  Does anyone have an idea? Please help.
Thank you in advance.
(6,505 Views)
It looks like the LabVIEW Sound and Measurement Suite would do the trick, or possibly Diadem, though I'm not sure if you have LabVIEW.  What program are you trying to open the file with?  It may also have a package you can download that supports all of the formats.  For instance, there appears to be a UFF file reader and writer if you Google "uff files" in the top result, but that's only if you were using a specific program.  But I suppose the easiest way would be if you already had the Sound and Measurement Suite.
Jake G.
(6,489 Views)
