SignalExpress
Strain measurement, Error 200022, Resource requested by this task has already been reserved by a different task.
Using Signal Express 6.0.0 with cDAQ and modules 9236 and 9237.  24 channels of strain data across three 9236's and one 9237 module.  All 24 channels of strain acquisition are within one Signal Express Step.  When continuously running program after first opening SE, always get error 200022.  After hitting Stop, then Run again, error clears.  Then, next time program is Run again, same error.  Then clears next time.  Cycle continues.
cDAQ chassis is reserved to my PC.
(5,835 Views)
Hi Menger
Here is a link that is related to that error, but in order to help you more it would be better if you post some screenshots of your application.
Regards
Esteban R.
(5,819 Views)
